- 10:39 PM
- Jan 28, 2016
- Dike, Iowa
Amen to that.That's Georgia red clay. Not easy digging. Being late winter early spring helped. After a 2 month drought in august it would be like digging concrete.
Haha, Ed your the only guy I know who actively discourages himself and then goes ahead with it!I've got a pair of 3816s that I dug out of mothballs for a change up.I took the carb off the one with no spark & put it on the saw that has spark & got nowhere.I rebuilt the carb,but it was a kit that had an acetate diaphragm,I absolutely hate them.The saw would start & run till the fuel ran out,then it'd just die & that was that.It has new fuel lines & primer bulb,new fuel filter.I had it running like a champ about 4-5 yrs.ago & I went to shut it off & it didn't.I pulled it apart to find the switch wire was disconnected from the coil.I plugged it back on & the saw would only run on a prime after that..I've come to the conclusion that any Mac saw under 54cc isn't worth a chit.So what do I do?I go & buy a 3200 for $27.I guess I'm a glutton for punishment.
Hey Mark, thank you very much for the excellent response, I haven't had time to respond until now but everything you said is golden.down-n-dirty - I've done some checking and no matter what the internet or the box told you, Oregon 10624 will not work on a 5/8" crankshaft. The bore of the drum .688" and the crankshaft diameter as you know is .625.
103688 is the same as several other McCulloch part numbers including 68866, 87111, and 90360 which are an SCE910 or just 910 bearing with an O.D. of .750".
As far as I know, the only large spline drum that will fit the 5/8" crankshaft for the large frame saws is an Oregon 10608 and is fit with a bronze bushing.
I have bearings (9/16x3/4) and bushings (5/8x3/4) that can be used in the large frame drums like 90359 but at this moment I am not aware of any spline drums with bearings that will fit the large frame saws using the 5/8" crankshaft.
I do have a few 60919 drums with bearings that fit the 5/8" crankshaft but they have a fixed rim .404-7 sprocket, not the splined/floating rim type that allows you to replace the sprocket independently.
Mark
