Vinnywv
- 12:21 PM
- Dec 22, 2021
- West virginia
Al, the sleeve material is cast iron sleeve from summit racing. The od is not touched. Just the id is machined close to finish size. It is then honed until its sized to the piston. The transfers are cut out using an old cylinder and scribed then cut out. Its pressed in then the intake and exhaust ports are cut out. I have 2 of them done. A sp80 and an 850. Both run just fine. The sp80 actually surprised me how good it ran. The 2nd one he did was an 850 cylinder and i was there the whole process. It took 4 hrs total. Took it home, had it all back together and it fired right up. It was very exciting thru the whole process. It took us months to get it all mapped out and tested and running. Lots of measurements and some trial and error. But it works. The q port exhaust is no issue either with the 800, 805, etc. Ive got 2 more cylinders to take to him. A sp81 and another 850. I can absolutely attest it works. I will add he needs a piston for final honing. The measurements he has are for a B piston.
