Mycamaro_68
By guess and by golly
- 4:48 AM
- Jan 28, 2016
- Cedar Rapids, IA
I will have to check tomorrow after work but i believe i have a complete pm310 that i would send you for the shipping cost.While digging through my shed last week,I found my other missing PM310 & PM320.I got these saws about 3 yrs.ago & I didn't know much back then.The clutch cover/chain brakes are missing from both saws.I checked for spark on the 320 with the plug that was in it & got no spark.I decided to try a different plug & presto! I had spark.I put some fuel in the tank & pulled about 15 times & got nothing.I gave it several primes & it fired on each one,but wouldn't draw fuel on it's own.I'd changed out the fuel filter previously.After several primes it started drawing fuel from the tank.I had to make a couple carb adjustments & it ran much better.The oiler works great on it,but now I need to pull the carb for a rebuild because after I let it set & cool off it won't restart unless I give it a small prime.It's missing the carb cover & filter,& the choke lever & throttle lock lever along with the top carb plate.I've got a couple chain brakes eyed up on Feebay,just waiting to hear back from the sellers.
