heimannm
6:42 AM
Dike, Iowa
The 33/35/39 series saws are pretty unusual in appearance but seem to be incredibly reliable starting saws. Once you learn a few simple tricks they are not that bad to work on.
A good 850 is indeed an impressive saw. Any of the 82 cc McCulloch saws are pretty snappy for that matter. The later PM800/805/8200 are much more quiet but not as much fun to run. The DE80 is a red headed step child but in good condition can hang with any of the 82 cc models.
My current 82 cc favorite is an SP81 with a NOS cylinder and piston that is just starting to break in. You must be serious when it comes time to start it.
Mark
T.Roller
7:42 AM
Southeast, TN
Mark
Thank you for the info
7:42 AM
IMO for what it's worth the later 82 cc models with eye brow ports and that quieter exhausts were not the runners the earlier models are .Being a bottom exit exhaust they used that muffler and screen affair which put too many bends and too much restriction on the system.If you want one to run very well get the muffler with the curvature in the bottom and the large cover .If you don't mind the noise remove the baffles .If you do mind the noise leave them in .Either one is an improvement over that wire basket thing .
A good running Mac 82 cc will run heads up with a Husqvarna 281 .I have both,I know for a fact .
T.Roller
7:42 AM
Southeast, TN
IMO for what it's worth the later 82 cc models with eye brow ports and that quiter exhausts were not the runners the earlier models are .Being a bottom exit exhaust they used that muffler and screen affair which put too many bends and too much restriction on the system.If you want one to run very well get the muffler with the curvature in the bottom and the large cover .If you don't mind the noise remove the baffles .If you do mind the noise leave them in .Either one is an improvement over that wire basket thing .
Randy had done a muffler mod on this saw. Its loud but not ear torturing loud. Seems to be a strong runner. Ill have to put it in some good size hardwoods to see it full potential.
heimannm
6:42 AM
Dike, Iowa
My SP81 with the cylinder and piston topped the two other 850's and the Husky 562XPW at the recent PNW GTG. Of course I had a little displacement advantage over the Husky. I have the stock muffler with baffle on the SP81 and you can hear it run.
Not me, but my 81 doing some fir damage. I believe he was nodding to his buddy John in this photo.
Mark
7:42 AM
A little note on the SP 81 I have.Flea bay find,PNW,cheap . Something was wrong with it,what I can't remember but I fixed it,Super compression for some reason .
I flooded that damned thing,lost my patience and drop started it .The decomp closed and walked the rope ,nearly got me .Never again have I made that mistake again. That one gets started on the ground.
T.Roller
7:42 AM
Southeast, TN
Cleaned up one of the 35's today. The condition of this saw is awesome!20160615_202157-1.jpg20160615_202207.jpg 2016061595202230.jpg2016061595202239.jpg
raumati01
11:42 PM
New Zealand
I'm starting to get quite a few of the 10 series variants now . Which carb kit would I need for a super pro 70 and does anyone know who sells them?
7:42 AM
Depends on the carb,the"book" shows two .Looks like a Tilley HS or a Walbro sdc but I can't be certain.
fossil
7:42 AM
Ontario, Canada
Most small engine shops or parts suppliers sell the kits.
If it's a Walbro SDC you want a K10-SDC kit
If it's a Tillotson HS you want a RK-23HS kit
heimannm
6:42 AM
Dike, Iowa
Here's what I am working on this week.
In the mix are a Mini Mac 6 (complete), Mini Mac 1 (less common), Mini Mac 25, Mini Mac 110, Mini Mac 140 AS (Auto Sharp), and a couple of SP510's. I will have to search around and see what other Mini Mac's I have ready to go. They made a lot of variations over the years, some have chrome plated bores and plain pistons, some have plain bores and chrome plated pistons, open port and closed port, bearings in the piston or bearing in the rod, etc. etc..
Mark
raumati01
11:42 PM
New Zealand
Thanks for the replies , a mcculloch fan has just listed 5 more 10 series on the local auction site. That's the mrs birthday present sorted, she's going to be stoked.
T.Roller
7:42 AM
Southeast, TN
Found these on ebay and couldn't pass them up. It was advertised as a service manual so it was a great suprise to find the IPL tucked inside. Both dated January 195720160622_211553-1.jpg20160622_211612.jpg 20160622_211625-1.jpg
merlin7734
Active OPE Member
7:42 AM
North Florida
Newb question for the experts.
If someone wanted a kart saw chassis, what models other than SP/CP125 are viable?
Sent from my MX2020 Secure Satellite Uplink.
