Dream
- 10:13 AM
- Aug 27, 2018
- Elberton, GA
Nice!
Cleaning up more for the museum, or new toys?
Nice!
Ok, I'm inputting here, then back to the yellow stuff I promise.Since it went off on a slant ,in my shop sits my dad's 1938 AC model B .I rebuilt that thing when I was a junior in HS .With a semi mount 14" plow it will pull the front end off the ground in sod .I also have his "cinder block" Mac 610 which he tweaked a tad bit plus the last Jeep CJ5 he built up from parts from three .
Nice Mark.That is an old photo, probably taken 10 years ago. I was just trying to get us back on track...
You may notice two SP105's in the photo, one went away and I took the other one out today for a good exercise on an ash tree my son had taken down a few days ago.
That SP105 had not been run in 3 or 4 years so it took a little prime to get it started the first time. After that and a tweak of the idle speed it performed flawlessly. Compression is down but is still runs and cuts very nicely. I'd say the PM55 and the SP105 make a pretty good two saw plan.
Mark
I bought this saw on Feebay yesterday.The ditzy seller says it's a model 3427 810 (new one on me).It'll need sopme work.I thought it might be a 2-10G,but others are telling me a 6-10.I'll find out when I get it.
They are a 57cc saw.Nice Mark.
Always wondered about the 55s.
Can you tell what the differences are, if any, between them and the 1010 saws?
Are they 54 or 57 cc?
Also keeping on track, I repaired some stripped threads and JB welded a hole into the oiler tank on a 610 today.
Didnt even look at the tractor.![]()
Dream - PM55, PM555, PM570, and the 10-10S saws are all 57cc and have something special in the porting making them perform much better than the 3cc advantage over the 54cc 10 Series saws would suggest.
Ed - RH start with the DSP would be 5-10 or 6-10. 5-10 would have the bullfrog carburetor (early) or a cube (later). 6-10's were all cube type carburetors.
Mark
Everything on the filter cover is printed in French from what I can tell.I bought this saw on Feebay yesterday.The ditzy seller says it's a model 3427 810 (new one on me).It'll need sopme work.I thought it might be a 2-10G,but others are telling me a 6-10.I'll find out when I get it.
