fossil
- 10:25 AM
- Jan 1, 2016
- Ontario, Canada
This saw is frustrating me. I rebuilt a second Tilly this afternoon, this one is an HL63E. It is pretty much acting the same although I did get this one to actually run, it is starving for fuel. It will only run on choke even with the needles 3 turns out. If I didn't know better I would think the saw has a massive air leak. Not sure where to go from here. I've never had a problem with the hi speed check on one of these carbs, also seems weird that 2 of these carbs are acting similar. It is worth noting, I am only changing gaskets and diaphragms because those are the kits I have on hand. I also ordered a complete RK88HL kit that will be here tomorrow.
Sent from my SM-G981U using Tapatalk
Let me know how that goes Kevin. The 63G I have has the brass cartridge type main nozzle check valve. I knocked it out and it fine. I'm leaning to a carb kit issue as well. I am wondering if the short barrel metering needle seat is an issue.
The original was a long one.
