Simpsonsawshop
- 10:06 PM
- Apr 17, 2020
- Townsend
I havent even looked to see if this is auto oiler or not.
You dont have any parts kicking around do you @Steve?
I just looked, it is an auto oiler.I think i sent you my last auto oil pump. Ill see what i have tonight. Im sure i have the screws.
Make a list!
That is what I intend to do, but I dont even have a battery box. Someone removed it and cut the wires.On that battery one of the guys in this area made one from the cells for battery drills .It's the only electric start I've ever seen .He was a lot like Mark,has more McCulloch stuff than you can shake a stick at .
Funny part about that is he hired in at where I worked,Ford engine plant .He had been there about a year and a half before I knew it .Met him three years before at a GTG .It was a big place 2.5 million square feet .
Find a battery case. Ive heard that Sub C cell lithium batteries can be had for cheap. Those are what are used in most cordless battery packs these days. Just need enough hooked in series to get to the required voltage.That is what I intend to do, but I dont even have a battery box. Someone removed it and cut the wires.
I have also heard Batteries Plus can rebuild them.
I've unlocked a couple of motors in the past year , patience and chemicals are your friends in that department. If it's not the starter housing dont despair.View attachment 254654 Got this 1-70 recently. Couldn't beat the price of free! Its locked, but the guard over the flywheel is bent in, and i think it may just be jammed into the flywheel. Havent had time to check it yet.
With ya on the Mini Mac. I have SO MANY.Or maybe a Mini MAC. That's just a we bit better than flagellation.
