Dream
- 9:46 AM
- Aug 27, 2018
- Elberton, GA
Can someone give me the part number for the smaller flywheel side seal for an sp81, the large seal the fits inside the bearing.
Also looking for sp81 rings if anyone has a spare set.
Got the PM6A back together with the parts that Kevin, AKA Gizzard sent me. Thanks again. Runs and oils, but having a little trouble getting the carb to take a tune. Anyone know the base settings for the Walbro MDC?
Low, high, metering lever height, and popoff pressure?
Yes it's a 700 ,I have one same number. Thats a later model number similar to the numbers they used on the 4300 saw.Stripping down two of my donor saws this afternoon.
The first one says its a PM700 on the filter cover, but it has model #60011602. Cant find that in the model number cross reference, but the one I have is from 1977. This saw may be newer. Anyone know?
The other saw that didnt have a filter cover is a 700. Model #600061D.
That oiler looks painful.Heres what the last 700 I just took apart looked like. No air filter present at all. Rings are completely gone. Piston and cylinder dont look terrible, in spite of all the crud it ate. View attachment 246185 View attachment 246186 View attachment 246187 View attachment 246188 View attachment 246189
I wasn't exactly sure what 82cc saw was gonna come my way so I purchased a project cylinder ( model airplane)thats a B casting from the same person. I bought them both for the exact retail value of the nos kit at the time he bought it .The famous "eye brow " exhaust port I see .The design idea is often a well debated subject as is the actual purpose .--I'll just keep my yap shut or rather my typing finger--one .
Thanks Kevin.I don't have access to my files right now (misplaced the darn hard drive they on). Maybe can try what is mentioned in this link for setting the metering lever. https://houseofhomelite.proboards.com/thread/2736/walbro-mdc-carburetors
Is your flywheel missing some fins?
Mark
Thanks Chief. I have one of those late models. I guess I could have just looked under the filter...Yes it's a 700 ,I have one same number. Thats a later model number similar to the numbers they used on the 4300 saw.View attachment 246416 View attachment 246417
Nice Mark! It was really nice to finally meet in person!Back from the PNW GTG with some additional stuff.
I will attempt to make one running 73 from these two project saws for Sawfun.
These will likely become donors for other projects.
Here is a fine catch.
Mark
Yeah they are completely machined off. The cylinder is in good shape but this one didn't come with a piston and connecting rod inside.Is your flywheel missing some fins?
Mark
I think they call those RC mini planes "giant scale " .I've seen a few of them but none with a revamped McCulloch engine so far .They are a hoot to watch as some get in "dog fights " trailing a streamer their opponent tries to chew off with their prop .There's a field about 4 miles away from me . They get a lot of money in those things .All the fins. I guess if it was a model airplane engine, then it would have enough air moving across it from the prop to cool it.
