- 3:38 AM
- Jan 14, 2016
- North western Ohio
Mac# 83859 --Cr 4913---https://www.motionindustries.com/productDetail.jsp?sku=01321111
It’s kinda hard to tell the tune without a full throttle piss rev, it didn’t sound blubber rich so it’s hard to say. Have you checked your points gap? What’s the compression at? Dose it four stroke?So the SP81 is up and running and oiling great. Thanks @Steve . I dont think I have the tuning right. It seems to be running well but it just seems slow. I started at 1 1/2 turns out on the hi jet and I think I am in to about 1 turn to get here. Should I lean on it a bit more? I just dont want to burn it up. 28 inch bar, stock chain off the roll 3/8
.050 full chisel.
When I took the video I didnt really intend to ask about tuning lol, that was an afterthought. This saw came to me as a runner, I did a partial teardown to repair some known issues. Pressure and vac tests pass, have not had a compression gauge on it but I cant pull it without the compression release. I have not messed with the points at all, I did think of that, maybe the gap is too tight and the timing is retarded.It’s kinda hard to tell the tune without a full throttle piss rev, it didn’t sound blubber rich so it’s hard to say. Have you checked your points gap? What’s the compression at? Dose it four stroke?
I agree al, I think it’s because of the very free flowing mufflers!For some reason McCullochs need to run a tad bit rich but not to the point of loading up .I'm not exactly certain why .
Agreed Al! Am sure that’s part of it too. My kart Mac likes it on the edge of too rich too, I was messing with it in the wood, and leaned it so it would just clean up in the wood and that’s were it had the most torque in the cut.That probably has something to do with .The few 10 series I've measured already had the exhaust port opening at 96 after plus in retrospect the transfers seem to be larger than most saws .So it might be such a thing it's blowing out a lot of fuel until the port time area open becomes less as the speed increases .
On the saw in question it would be easy to figure out.Just tweak it in the cut or rather as cutting with it .
On a solid state ignition coil it might be easier too open up the holes in the lamination and tweak the timing that way.Sounds like you need to verify where the points are, then tweak the tuning on the high side til it gets to the sweet spot.
My PM700 is solid state ign. I had to go thru the carb because I fed it some bad fuel. Just got it out at the log pile and tweaked til it ran right. It pulls hard. Always has. Good torque. I wonder if it's got anything to do with the ignition timing? Its all bone stock. Ive always wanted to make an adjustable coil mounting plate versus machining off the flywheel key. Would be way easier to make minor adjustments without having to pull the flywheel, once you got the machinework done to mount the coil.
