- 4:09 AM
- Jan 14, 2016
- North western Ohio
If you could find some 5/16 -24 flange nuts you could ditch the washers.
Nice find!I picked this up while on vacation. Great compression and it fires up easily.
I have never seen a 10 series that throws this much bar oil. I'll have to get in there and back it off.
The front handle bar appears to be bent back a bit and I'm not sure if the muffler is original to the saw.
I like the 70cc series and have a PM700, another 7-10A and a 5-10A that is waiting for me to find a good RH starter assy.
View attachment 32989 View attachment 32990 View attachment 32991
Hey Tim, Ya ever need anything from Mcmaster carr or anywhere
else that won't ship to ya let me know. I'll get it to ya. Not a big deal.
I'm sure you know that impulse oilers pump as long as the engine is running as opposed to most saws which only oil when the chain is running .Mac designed impulse oilers will properly lube any bar the saw was designed to run. I've ran up to 32" bars on 70 cc 10 series saws and have no doubt they could oil a 36" .I've never seen one but have heard they made up to 42" bars at one time most likely used in the PNW on 82cc Macs .It's pumping enough that it's running down the sides of the bar and makes quite a mess under the clutch cover.
What do you guys normally set them at or is it a saw by saw setting?
The saw is very smooth for a rigid mount saw.
Wow this looks almost identical to a super 250 I picked up a while back which is also 87cc.
What's the difference?
The 650 has the hidden geardrive behind the clutch cover.
