- 8:31 PM
- Jan 24, 2018
- Extreme Southeast CA
Mebbe one morning this weekend. Or bring up there…
All the hardware in your luggage pretty much guarantees you a cavity search at airport securityMebbe one morning this weekend. Or bring up there…
Maybe he's hoping for it . . .All the hardware in your luggage pretty much guarantees you a cavity search at airport security![]()
I think I’ll stick to squareI tried it on a stock 266 in dry wood. Doesn’t self feed well. Might if I dropped rakers? I also did some face clean out cuts. Did pretty good, Grabby on the corner of the chain. Baby c was better. Also plunged and sliced a cookie off the top of a vertical chunk. The top/back of the bar/chain seemed to want to catch and push/kick. Overall, meh. I think the round file creates a hollow grind that cuts better. I haven’t tried the file yet but I think the best thing about it is the dummy resistant smooth sided file for file height.
@Woodpecker
After filing, even in the hands of untrained users,
Be forewarned when your Stihld maiden shows up in Chain mail!i hope so..
you buy a kit first, then let us all know
Nah she's got the hamburger & needs some pork sword …
a bit of persuasion and I think they will peel off her..
Triangulare' !
The Hexa file I got came from Sweden.
It has not been put to the test as new chain is sampled.
The file does lay perfect under the top plate, sets on the side plate and the gullet.
It is pretty awesome.
A few strokes and you are gtg.
This Triangulare' is a one and done deal.
Sent from my SM-N975U using Tapatalk
MOBILE-Milwaukee battery grinder with the cutting wheel gets the tooth beak and side plate sharp fast! No sandpaper belts necessary!It’s a tiny belt sander powered by a cordless drill. Abrasive is abrasive.
I contacted them, a few years ago, about getting a unit to demo, but nothing happened.
Using it for square ground (sanded?) will take some thought.
Philbert
