Stihl 1125 (034/034S/036/360) Cylinder/Saw ID
Stihlsmoking
City Hillbilly
2:00 PM
Cincy
4:00 AM
A few things i noticed today when comparing 034's......Note the cylinder to crankcase clearance on the 034 as compared to the 034 Super,also note the ridge that runs past the transfer port,its a cast in part of the crank case.
DND 9000
8:00 PM
Germany
The 4 stands for the austrian factory.
I only knew battery/electric Stihl products made there in the Viking assembly halls.
This 041 has a 8 digit serial.
Those digit wont show you where this saw was assembled.
1= germany
2/5 = usa
4 = austria
8 = china
9 = not produced by stihl ;)
OK, I see that I´m wrong. Sorry. I had a look at a old TI. They changed it and now 4 is for Austria and in the past it was China.
2:00 PM
Maybe it isn't all original? Maybe someone used different cases or plastic?
Have someone run the serial number through Stihl computer.
Jimmy in NC
2:00 PM
North Carolina
Ok... so I've read through most of this. Is the consensus not to use a heat shield if using the spacer?
Sent from my SM-G955U using Tapatalk
