Stihl 026 rebuild
2:39 PM
I'm quite interested in what it tachs at.
Which air filter did you use?
czar800
2:39 PM
Ellwood City
A tach is one of the only things I don't have. Air filter Is stock... I have a 260 that I may swap with just to try. What's your thoughts about the artic filters from Stihl.
2:39 PM
Run it with and without air filter.
This is a case where the OEM (rare) metal filter is needed.
Even the smaller metal 024 filter flows more than the flocked AM 026 one.
czar800
2:39 PM
Ellwood City
Al do you have a link to the metal mesh that you planning on using.
petedaycab
let's roll some coal...............
2:39 PM
Indiana
I have had trouble with the AM flocked filters. Seems the saw(s) with even just a MM do not like them. I have found a few of the wire filters on eBay , they seem to allow the best flow/RPM's. I realize they do not give the best filtration through. I have owned my 024 super since new, and it is still on its original jug, and just its second set of rings.
2:39 PM
Czar,
There's the fine mesh, what you want, and then there's the worn coarse mesh with the flicking missing (what you don't want.
czar800
2:39 PM
Ellwood City
Ok I got the saw into some wood today and I wasn't impressed.... I run it with and without the air filter. It definitely ran better without the filter, but was no ball of fire. I believe my ported 024 would out run it!! The saw came out at 104-117.5-79 I really think I need to get the intake up to 70-75. Any input would be helpful and I'll try to make a few videos over the weekend.
Brian Simonseth
CANCER AND STROKES SUCKS
11:39 AM
Stanwood, Washington
I bought this wire mesh air filter from Wood's a Stihl Dealer in Sedro Woolley Wa it was a stock item there two years ago
2:39 PM
Where did the 79 intake come from???
czar800
2:39 PM
Ellwood City
I'm going to double check that. I must of had a Brain fart!! And lowering the intake...
czar800
2:39 PM
Ellwood City
If so I'll JB it up to? 70* man I feel stupid... Some times I put too many irons in the fire. I fix saws to relax and learn.
2:39 PM
What compression?
Makes little sense it would run badly.
czar800
2:39 PM
Ellwood City
This is from before I even started it. Say 225
czar800
2:39 PM
Ellwood City
I ripped it a part and the intake is a 79* so I JB welded it.
2:39 PM
This MS260 is running one ring because I made the intake a bit too big. Biggest intake I've done on this model. I coulda run 2 rings, but I felt I was too close to the ring gap. I lowered the intake also-what a 12pack will make you do while porting.
Final numbers 103.5/118/78, comp 225.
This one loved to rev but was a bit short in the torque department. I was thinking of going with more intake (like you did and I did on this one) in my next build. This was the highest revving 026 I've done. It was happy at 15,800. The others have been happier at 14,000.
Yours should outrun a ported 024 though. Not sure why it isn't.
