So what's the current two stroke oil favorite?
CR888
11:50 AM
I think Steve took things a little too serious, sometimes a break from the forums is a good idea if it's raising your blood pressure. Owners/moderators etc are not afforded that leisure. Even after cattle bust Randy's fences and Bubba & his mates fire up the pipe saw with straight gas for a piss rev session he still has to check in here to make sure the OPE heard isn't tearing one another to bits over yard and forestry tools....or oil. We are a funny bunch to say the least
rogue60
10:50 AM
AU
Oil is serious business ya know some dudes lose their chit over oil LOL
Yeah He was a little over the top sensitive picked up on that way back I stayed away from the hole whipper snipper oil testing thing for obvious reasons...
Wanab
7:50 PM
USA
Yeah sometimes you can show people in black and white and they fail to see through rose colored glasses. On the other had 300:1 testing would off little in the RW of chain saws. If you think it would protect you from being lean your mistaken. Your air/fuel ration would have to be 6 times leaner before you got there and would have hard locked a long time before. That is respective of you adding strait gas to a 50:1 mix. No way a 50:1 mix breaks down to 300:1 because of a lean tune. I guess my point being that I am a bit hard to understand at times is the lack of fuel causes seizure and not the lack of oil when properly mixed and 1000:1 would not protect you.
D B Cooper
44:1 Bel-Ray MC1
7:50 PM
somewhere
It is a 201tc. The ring end gap is great. I just cleaned it up then reassembled.
The M-tron is overfeuling it bad.
Kiwioilboiler
346 Pic Examiner
1:50 PM
Marsden Pt, NZ
I don't think that was ever the point Mr WannaBee. Was always about how much excess protection was built into a given oil, the logic being if it can lube at 300:1 correctly tuned, then it sure will and some at 40/50:1 correctly tuned too.
Wonkydonkey
Plastic member
12:50 AM
Sussex, UK.
Also it speeds up the process.
.however heat is a process of seizing and the wrong mix will add heat as the fuel/air/oil ratio is wrong , ie then the oil not lubing as it should.
So if an oil can run longer @ 300:1 then it’s got better lubing qualities.
i,m guessing the air fuel mix is a side thing… ie your ears hear it not 4stroking @wot so you retune.. then find it’s gone off tune again.. so get it checked out before it seized..
but on the other hand… oil and carbon deposits is also a problem. So if it’s a cleaner running oil @ whatever ratios that’s something else to factor..
I try not to add my thoughts to any oil thread thing, just cos I,m cheap and use what ever I buy.. I'm able to fix my own saws so a decarb is just a yearly maintenance just like maintaining other parts of saws…
So I’ve added my thoughts for this yr.. maybe next yr I will add a bit more
:risas3:
7:50 PM
Boy that didn't take long first guess got it.
I've rebuilt 6 or 8 saws running ultra
Mostly new saws
That didn't take long to stick rings with that crap.
No issue's with orange bottle I can remember.
I know a logger who bought a couple 661s
When they came out
He ran the recommended ultra
He said he ran 50/1
Who knows
But both saws didn't make it long
I don't know what he did with them
But he runs 395s now.
Wonkydonkey
Plastic member
12:50 AM
Sussex, UK.
Mostly new saws
When they came out
He said he ran 50/1
Who knows
that’s interesting, cos I heard stihl made the ultra for there 4mix engines due to the carbon buildup with the red stuff in the 4mix.
also here if you buy the ultra with a new saw they give you an extended warranty.. I just see it as marketing bs so you carryon buying into the stihl package..
edit, my mate brought a new saw got the ultra for the longer Warranty, and never used it.. as he uses stihls “Motor mix” (Aspen the Alykulate fuel ) with the oil already mixed o_O
That’s how I got mine for free.
7:50 PM
In real world use it sucks ass.
Wonkydonkey
Plastic member
12:50 AM
Sussex, UK.
If I said the same friend, got a 880 with 42” bar and chain for less than 1/2 the retail price directly from stihl.. you would know that stihl is just about selling stuff with a high markup with the stihl branding…. Great if you can get it, crap if your not in the club.. so I understand when you say crap in the real world of oils
I’m me and I shop around..for a deal as I’m not in the club o_O
ahh to much oil talk this yr, I got sucked into it :tiburon::risas3:
pbillyi69
4:50 PM
USA
the oil i have used the most is the original husky xp oil when it first came me and my couson bought a five gallon bucket of it for about 90 if i remember correctly that is also when i started running at 50:1 because they said we could without voiding the warranty on our saws. never had an issue with it. burns clean and doesnt smell bad
Wanab
7:50 PM
USA
The problem with your logic is that oil you love so much at 300:1 may not make the top 5 @40:1. A lot more to oil that just max wear protection @ extremes.
