Simington / Silvey Square Chain Grinders Tips/Tricks/Secrets
12:59 AM
Pretty much. Single works better for shaping the wheel the first time.
Deets066
AKA Deetsey
12:59 AM
Interesting. My tooth may be appropriate then. I was going under the assumption that vertical was the desired side plate angle. Mine does slope back away from the tooth point.
Ok, that should be fine then. I had thought you meant it was sloping the other way
Sierrawoodsman
12:59 AM
Dayton Nevada
You only need an angle finder if you want to copy someone else's angles. Pictures will help. If you can't get them to post I'll send you my number and you can text me.
I went ahead and documented the dress angles I put on the new stone that I tried to copy from Deets picture's.(which I do anyway when I change thing around.)
To me the first cutters he posted were about as close to ideal-(in my mind) as I have seen with the grinder. I know that you have a Simmington, but I would think that provided you have the wheel mounting height, and the stone dress angles should produce a very similar cutter profile.
Like Mike said all you need is an angle finder. They're pretty cheap at Harbor freight. Even cheaper is this app, as you probably have a smart phone. The app is dead nuts accurate as compared to my Wixey angle finder.
(iPhone) - https://itunes.apple.com/us/app/clinometer-+-bubble-level/id286215117?mt=8
Android-https://play.google.com/store/apps/details?id=com.plaincode.clinometer&hl=en
First I would recommend you level your grinder as shown:
Then remove the diamond dressers and place angle finder on the top plate diamond dresser swivel as shown below- (approx 12 degrees):
Finally repeat the same procedure for the sideplate dresser as shown below:(approximately 15 degrees)
Now just reinstall your diamond dressers. Dress the stone and try sharpening a cutter.
Hope this helps you.
psuiewalsh
Basement Bodging
12:59 AM
Nottingham,pa
Neat. My silvey looks similar to yours. I will have to try the hf angle finder.
Sent from my C771 using Tapatalk 2
psuiewalsh
Basement Bodging
12:59 AM
Nottingham,pa
Mike. This last picture you posted is what i tried with the chain rest. It seemed better with the rest tilted up.
Deets066
AKA Deetsey
12:59 AM
I might pick one up today too, it would've nice to know where I'm at
Duane(Pa)
It's the chain...
12:59 AM
Centre County
"Chain Rest"?
Are you talking about the grooved piece that the drive links slide in? If so, the tilt doesn't matter because of the arc radius. The only change comes from moving it fore or aft on the arm, or up down vertically. (from the Simington setup video)
super3
12:59 AM
Indiana
I talked to Kelly at Simington. He did tell me the cluster point dressers produce a much nicer finish on the wheel,
He told me just the opposite when I wanted a multi point added to my order a few yrs back.
Duane(Pa)
It's the chain...
12:59 AM
Centre County
What model do you have? Mine is an older 450, and has a simple pivot screw for the dresser to rotate around. Apparently, the 451 has some sort of enhanced bearing in the dresser pivot. Lacking that bearing on the older model, he said the cluster was the better choice.... IDK?
12:59 AM
Those were the only pictures I could find on my photobucket.
super3
12:59 AM
Indiana
I didn't say I agreed with what he told me, that is just what he said at the time. I bought the multi point anyhow.
I have a 451C. It does have bearings on the pivot levers.
