Simington / Silvey Square Chain Grinders Tips/Tricks/Secrets
tek9tim
6:57 PM
Winthrop, WA
Bump
Hey- I've read up to page 46 on this (and others as well) and did searches on the fourm but have so far seen no mention of this grinder which is currently available at Baileys from time to time.. does anyone have any experience with these? Gotta say to me it sounds good and is cheaper than what you would pay for some of the old Silvey models.. opinions? Thoughts? Experience? Please share any you have.
I bit the bullet at work, started a separate thread on it. TL;DR- I like it, but needs improvements like every other square grinder.
jacob j.
Only the weird
6:57 PM
Coastal Oregon
Link?
Thanks!
Philbert
Khntr85
9:57 PM
Indiana
Ok boys I got a chance to get a Simington grinder I believe it’s the 450 because it doesn’t have the adjustable arm cheap 300-400….anyway I just got that square jig that goes on my Oregon grinder and it’s amazing can churn out a killer chain (I can post some cutter pics), it seems like not to many people have one but if you aren’t new to grinding it makes a perfect square chain!!!
Anyway just wondering if the Simington worth it as I know it doesn’t have the adjustments of the newer 451, I’m not lazy but don’t want to mess with shimming the motor to get more angles….i am thoroughly happy with that square jig, but don’t want to pass on something I would regret, but I don’t want a grinder that won’t be any better than the square jig ya know….
Anyway just wondering what your ya thoughts would be on it?!?!?
Duane(Pa)
It's the chain...
9:57 PM
Centre County
I had a 450. Made a good chain. The guy I sold it to has no complaints. The dressers shape the wheel, and that is where a fair amount of the tooth shape comes from. 3-400 sounds like a pretty decent deal...
pbillyi69
6:57 PM
USA
you can buy a simington adjustable arm too. if you dont care about changing angles. that 450 will be pleanty good. they make a sharp chain.
Duane(Pa)
It's the chain...
9:57 PM
Centre County
Kelly at Salt Creek told me the arm is not interchangeable. IDK never compared the two. There’s a thread on here where SCarr mills slots into the arm. No idea what that mod costs.
Wolverine
dilligaf
9:57 PM
That's a great deal IMO. I think it would be a better choice than your other one, mainly because you can very quickly advance a cutter and back it up into the (adjustable) chain stop, grind, move on. The second main difference I see, on the 450 you need to adjust the wheel dressers to really change the profile you are grinding. I do mill and it would be great to have a wheel just for that but I haven't done it (have the wheel, don't have the time).
Once the motor is squared(shimmed) to the mount, no need to tweak there, IMO. That's a set and forget. The adjustments come from dresser angles and where you position the cutter. Mine was modded so the chain holder is on an essentric. I can significantly raise and lower chain height. Pics are on this thread I believe.
Khntr85
9:57 PM
Indiana
Appreciate the info!!!
From what I have seen looking at pics of both, the 451 has the adjustment where you can move the “part that holds the chain”, forward or backward more…which from what I can see would give the option to make a more or less aggressive tooth….
Don’t happen to have a pic of a tooth you sharpened with the 450 by chance??
Khntr85
9:57 PM
Indiana
Hey lol didn’t know you had one or would have asked ya on the phone lol….
I’m goin to post a pic and circle the part I’m talking about but I didn’t know if you can get diffrent tooth profiles by moving the part that the chain sits in…
Khntr85
9:57 PM
Indiana
I know that’s a 451 I’m just using th photo so you guys can see what I am talking about…
Does it change the tooth profile if you spin that forward or backwards, or does it not change the profile regardless of where that is holding the chain????
Khntr85
9:57 PM
Indiana
There is a chain I did on square jig, I have plenty room and adjustments to go more/less aggressive…it’s pretty cool honestly… I don’t cut wood for a living. I’ve heated for probably 15 years with an outdoor boiler and I cut wood for my father-in-law so in all reality, this thing would be plenty for me, but we all know how that goes always something “else” lol
Duane(Pa)
It's the chain...
9:57 PM
Centre County
Khntr85
9:57 PM
Indiana
Look closely. There are four angles to consider.
Ya I was just curious how much adjustment there was on the 450 on the machine itself…I know you can dress the wheel to get whatever profile you want, I just didn’t know if it had any adjustments on the machine itself
