Bryan Marks
- 1:23 PM
- Jun 3, 2018
- Bakersfield
I might be being to precise. Like I said I have not ground chain yet but I have a mechanical brain. If I had to guess the arbor is 2 thou. Out of round and the under side of the wheel at the end where you index the tooth is prob 10 thou. Up and down when the wheel slows down. The top corner of the wheel that indexes on the cutter tooth looks to be perfect on the plastic guide that the chain sits in. I’ve done a bunch of measuring back and forth and it seems to be good from side to side on night and depth. Has anyone measured the run out in the bottom of there wheel towards the tip of the wheel?I’ve take the wheel off prob 15 times today to check stuff. I need to put a dial indicator on the shaft. I’ll be in the shop Sunday.
