ROUND Grinders only
Red97
5:51 AM
MI
What is the fixed angle on the head (55°-60°)? Im not worried about the vise tilting was just wondering about the head tilt.
The 510a head tilts the 410 doesn't so what is the angle on the 410? I would assume 55° as most Oregon chains are 55°.
The 410 has head tilt.
KenJax Tree
¯\_(ツ)_/¯
5:51 AM
Over there
Ok thanks Joe. Someone said it wasn't adjustable for different angles and it didn't look like it did in the pics.
Crzybowhntr
Apprentice Slacker
5:51 AM
WV
I've lost my wheel shaping stone. What else can I use to shape it? A flat piece of limestone?
Red97
5:51 AM
MI
This should be the head tilt on my 410.
Philbert
Chainsaw Enthusiast
4:51 AM
East Dakota
3 Angles:
Grinder head tilt.
Vise rotation.
Down angle.
Specs for the current grinder models are in that chart I posted earlier.
I don't think that the 510 has the down angle (10 degree) feature. The 310 has a fixed head angle at 60 degrees.
Philbert
Philbert
Chainsaw Enthusiast
4:51 AM
East Dakota
You can order a replacement stone from Oregon.
You can also buy a wheel dressing stone at many hardware home center stores. I have bought larger ones at those places, and broken them down into smaller pieces, for use with these grinders, by placing them in a vise, and tapping them with a mallet.
Philbert
KenJax Tree
¯\_(ツ)_/¯
5:51 AM
Over there
3 Angles:
Grinder head tilt.
Vise rotation.
Down angle.
Philbert
It looks like the only advantage of the 510 is the bigger motor. Im only sharpening my chains so the smaller motor will be fine for me.
Thanks for the info guys[emoji106]
Firewood Bandit
4:51 AM
Philbert
Once you use a diamond dresser, you will never using a stone or brick again.
http://www.walmart.com/ip/47784000?wmlspartner=wmtlabs#about
This video will give you an idea of what they are.
Philbert
Chainsaw Enthusiast
4:51 AM
East Dakota
That looks like a nice tool for squaring up a grinding wheel. I dress the sharpening wheels infrequently for shape, and frequently to expose fresh grit.
I have the small, coarse grit, silicon carbide stones that come with the Oregon grinders. I also bought a half inch by half inch by 6 inch stone at Fleet Farm for about six bucks, that I broke into 3 pieces, just to try.
These work fine for me, and will probably out last me.
Of course, I also use the conventional vitreous grinding wheels, instead of the CBN ones, so I might be a cantankerous old fart in training!
Philbert
Firewood Bandit
4:51 AM
As the video explained, the diamond dresser actually fracture the grains of grit in the wheel making a finer finish and taking very little off the wheel. Besides, they don't cost any more than your brick and they should last forever.
KenJax Tree
¯\_(ツ)_/¯
5:51 AM
Over there
What size carriage bolts will in need to mount it on my bench?
I could just look at and decide but i was gonna get the bolts before i got the grinder.
Philbert
Chainsaw Enthusiast
4:51 AM
East Dakota
I mount mine to a wooden board, then clamp the board to the bench. This lets me move it to other work locations, and store it when not in use.
Philbert
KenJax Tree
¯\_(ツ)_/¯
5:51 AM
Over there
Philbert
I was gonna use wing nuts under the bench so if i needed to move it I could easily.
Did you use lag bolts so they didn't go all the way through the board?
Canadian farm boy
“Normal” people scare me.
5:51 AM
Ontario, Canada
I've got my grinder mounted to a piece of 2x4. When I need to use the grinder I just clamp it in my vise. Same idea as Philbert just a slightly different way to do it. It's all a matter of what works for you. I believe most grinders also have mounting holes in the back so you can mount them on a wall
