Stihl working Hard
Is it Friday yet
- 9:13 PM
- Feb 6, 2016
- Perth Australia
I can feel my arteries hardening
Ough I believe thatWhen are you coming to Atlanta Dan? That is at a local landmark called The Vortex. They call it "The Triple Coronary Bypass Burger." LOL
I chased my tail recently on a 10mm that had a new tank installed by a Stihl dealer. After the saw wouldnt run correctly they charged the fella for a new carb.
Saw still wouldnt run right. It landed on my bench. After messing with it for a bit a buddy questioned if the snorkel hole had been opened on the new tank. Thats all it needed and saw runs perfect. Dude got beat down by a dealer.
Or worstRedneck repair at its best.
the 044 had 3 air filter bases i can get pictures in a little bit one was set up for no snorkel one had snorkel but was blocked off and the other has the opened snorkelPics of the snorkel hole Jon?
What John was talking about and the piece that wasn't blocked off on the 064
One possibility. The other would be what maker of bearings in particular were used in the saws that failedQuestion:
I've seen some posts that imply saws had a failure because Jason used AM wrist pin bearings instead of OEM.
I have also seen posts reflecting other damage that was likely due to Jason not cleaning his cylinder grindings out of the saw.
Since I am currently running an AM piston pin bearing in my Flying Tiger 660, so far w/o any issues, is it likely some of those bearing failures were due to Jason leaving debris in the saw (instead of the bearing itself being faulty)???
Seems like a real possibility to me.
Jason had at least one catastrophic failure due to an AM pin bearing (ported saw I think). I think he posted some pics but I'm not sure. It's possible, yes. Others have had issues as well. I'm done using 'em but I probably won't go back into saws that have them (5 or 6 I bet).Question:
Here's the carb after a proper rebuild.
View attachment 81770 View attachment 81771
And some work on the muffler.
View attachment 81772 View attachment 81773
So should i get the 288 piston outta my 660 ?
