Play time?
Red97
4:58 PM
MI
That looks fragile. Not much cast iron holding above the intake. Your effort impresses the crap out of me!
If I do decide to use them. It would just be 2 ports that poke through the new sleeve.
Once it was finished. It would look like a 6 transfer engine.
Wow, got some time in that one. Very cool work Joe
Thank you.
I go and dabble with it a few hours each night.
Red97
4:58 PM
MI
So I guess I'm going to change directions for a min... going to do a 50mm 044 cylinder. Still 73.85cc. I think it can be stronger than my echo 50mm... which was only a couple seconds behind the 52, 54mm saws.
Woodpecker
Sassy Madam
4:58 PM
It puts the shiny piston in the cylinder or it gets the hose again!
Love that shinny red. Will be interesting to see how it stacks up to the other 50mm saw.
Red97
4:58 PM
MI
Me too, I've always wanted one.
I'm going to try and make this 50mm rather sporty.. 20" bar saw.
Stevetheboatguy
3:58 PM
Nw IL
YES! This is the one that needs to be built Joe. Bet the 50mm turns out mega strong.
Steven
Red97
4:58 PM
MI
Got the sleeve out, boost ports roughed in.
Looks like it has seen better days... Sure hope I can make it run again.
Plan on boring it out .015 ish to clean everything up. Once the piston shows up, I will make the sleeve to fit the new bore.
Has been a fun project so far, hope you all have enjoyed the struggle....
MG porting
1:58 PM
Wa
Heck yeah I hope it works out for you that's a lot of work and I think it will turn out to be a good runner.
Red97
4:58 PM
MI
044 all welded. This one took a bit more weld to get to the width.
Cleaned up my template. Easier to trace the base and make them match.
Definitive Dave
Piss Rev Mafia Member
4:58 PM
Central Ohio
