XP_Slinger
They’re Just Saws
- 1:48 PM
- Feb 9, 2016
- Central NY
Wow, got some time in that one. Very cool work Joe
That looks fragile. Not much cast iron holding above the intake. Your effort impresses the crap out of me!
pop some external transfers in there
Love that shinny red. Will be interesting to see how it stacks up to the other 50mm saw.View attachment 230769
So I guess I'm going to change directions for a min... going to do a 50mm 044 cylinder. Still 73.85cc. I think it can be stronger than my echo 50mm... which was only a couple seconds behind the 52, 54mm saws.
It puts the shiny piston in the cylinder or it gets the hose again!
YES! This is the one that needs to be built Joe. Bet the 50mm turns out mega strong.
Steven
Heck yeah I hope it works out for you that's a lot of work and I think it will turn out to be a good runner.View attachment 230786
Got the sleeve out, boost ports roughed in.
Looks like it has seen better days... Sure hope I can make it run again.
Plan on boring it out .015 ish to clean everything up. Once the piston shows up, I will make the sleeve to fit the new bore.
Has been a fun project so far, hope you all have enjoyed the struggle....
make sure your bore is compatible with the Chrome faced steel 1mm rings that come standard with Wiseco pistonsView attachment 230763 View attachment 230764
Have my piston ordered. Not much can happen until I receive it.
55mm, 1mm ring centered pin.
