MG porting
I would try running two rings in it before putting a different piston just for poop and giggles.
Jeez,
Afterthought, grind in a tonsil or Mickey Mouse it like IH next time?
Think top ring wearing at that roof or vice/versa?
I bet it lives. Personally I’d run it more and see if the rings wear into the bore. Maybe a light honing with a 3 stone?
Sell it to the EPA as the new hotness in two stroke EGR.After more thought, I think this jug is all for not.
If I can't get the ring to seal in the intake, it will just keep ingesting the exhaust.
Patent that bish!
Well maybe 3rd time will be the charm...
I have some larger od sleeve stock.
Open the jug another .015-20 get it good and round again. Turn o.d and i.d of new sleeve and try again.
Aim higher. Edison failed a 1000 times before he got the lightbulb right![]()
And that's a bummer. But u could make another sleeve and make the intake roof lower and fill the intake bore with jbView attachment 230035
I was afraid...
Forgot as the bore gets bigger the intake goes higher... That is both rings in the intake port.
You just had to bring up IH didn't you.Jeez,
Don't be so hard on yerself Joe. It's still innovation and that takes a bit of failure.Well this isn't uncharted territory.... it's just not quite a yellow brick road either.
Done yet?Ok, change of plan.
After some mulling over, lots of head scratching. Good conversations, and even a nap..
I am going to toss out the 56mm sleeve idea. Just not enough material for the sleeve to stay put. I had heard .080 minimum wall thickness, just didn't want to believe it.
Plan b
Sleeve to 54mm
Add transfer dividers, make bottom fed to match the case.
I'll use a 660 piston because i have it.
Open to 54mm 12mm pin full circle ideas
Save my pennies and send out a cylinder to be bored and plated 56mm
The 54mm will leave me with .100 wall minimum. Well within the range i need.
Have dualing 86's ...
Done yet?
Hey now I thought Mastermind said he doesn't rent pigs.View attachment 230240
Piggin...
Hey now I thought Mastermind said he doesn't rent pigs.![]()
Lol. No pigs but you can send me some bacon tho.How many you want? Got about 70 to sell off the end of the month. Things are starting to eat lol
