- 11:28 AM
- Dec 31, 2015
- East Jordan, MI
It’s there on the new model, but it’s on the exhaust sidePerché vedendo il carter modello nuovo non lo ha
There you go being sophisticated again!Ha qualcosa di più semplice, ma è verso la parte anteriore della sega.
And stuff !!!There you go being sophisticated again!
This time of year I help out at a local saw rebuild shop, on my bench are 11 ms462, older style, with cracked pistons, 3 of those also have stripped plug holes too. They are all waiting on cylinders. Sounds like they got 2 years of hard use out of them, all from a tree service company. Rest of the saws im rebuilding are 4 572xp bad crank bearings, and one ms440 in for restoration.
On the 462 subject, I actually see way more of those and 500i's come in that have stripped plug holes than cracked/broken pistons.
I would still own a early 462. But knowing what I know, I would just swap the piston out after a season of full time sawing. It appears that the crack is caused by wear, and excess piston skirt slap. Slapping skirts is my thing so there is that lol
The only ones I know of were mtronic, but the carbed version wasn’t readily available here then, either. The design change came around at a similar time as the standard carb 462 became available hereAre the 462’s with cracked pistons all M-tronic ?
Same questions applies to others who have seen the issue.
@huskihl @Mastermind
Are the problem children all M-tronic 462/661 ?
I am guessing that they are in the US since the adjustable carb version of the 462 came from out of country.
I am unsure of what the have over where @markds2 is ?
Not following? Standard carb models are still not available here in Sweden to the best of my knowledge. Southern Europe is another matter.I knew they made the 661 standard carb available again here but wasn’t aware the made the 462 standard carb available here.
Thanks Kevin
So we can know start the debate about standard carb vs m-tronic on piston failures in Stihl saws…
Aren’t there some Stihl Kool-aid guys in Europe that can shed some light on this ?
Isn’t @BonScott46 one of them ? If not I humbly apologize for any hurt feelers.
Thanks Kevin
Also, I believe the standard 462 is the only one readily available here now, due to the shortages of MTronic wiring harnesses from UkraineI knew they made the 661 standard carb available again here but wasn’t aware the made the 462 standard carb available here.
Thanks Kevin
My dealer can't even get 462's or 400's. He has been able to get 500i's and adjustable carb versions of the 362....haven't seen 261's in a long while either.Also, I believe the standard 462 is the only one readily available here now, due to the shortages of MTronic wiring harnesses from Ukraine
No idea, i doubt there are many pros running Stihl let alone 462's in my area to be honest.I was just curious as to whether or not they having issues with cracked pistons in the 462 in your neck of the woods ? I couldn’t recall what areas only allowed M-tronics vs adjustable carbs.
I haven't had the luck of turning wrenches on a non mtronic 462. I'm pretty sure the non mtronic 462 in the USA are all the newer version (ones that were sold here)Are the 462’s with cracked pistons all M-tronic ?
I am guessing that they are in the US since the adjustable carb version of the 462 had to come from out of country.
I am just curious as to any correlation between carb setup/failure ratio ? It doesn’t appear to be a massive problem but just curious. I would imagine that the operator has more to do with it than carb type. Maybe they all start chitting the bed at 1000 - 1200 hrs.
I agree.. And if my memory is right, you've port a few standard carb 462s from Greece.
I doubt the piston cares if its m-tronic or not.
