- 6:08 AM
- Dec 30, 2015
- Brewster, NY
I'm guessing that because I did not sand, or use brake cleaner on the case before going "gasketless", that it did not seal properly.
Ironically, I actually had a little bit of time today and started to take the saw down.
I will try that first, and I have a new AM coil & carb if that does not work.
My time will be limited until 4/15, but I may work on it a little here & there.
I plan to have it at the Upstate NY GTG, so another toy you can try!
I was going to put a vac tester on it, but it looks like it would be hard to determine where the leak actually is, so I will just try this first. Time is limited right now.
