Mastermind Meets The Dolmar 7900
mdavlee
Hillbilly grinder
6:27 PM
TN
Same here.
I just did a 7910 jug on a Solo 681 at 97/125/82.
It's my best runner yet.
Matt's saw was 95-96 126 81. I cut the chamber and lowered the jug a little and slowed it down with 95 126, 86. I raised the intake back up yesterday. Going to try it today. It was 165-170 on compression before and was a little higher after. I forgot to test it hot. I still need an unlimited coil for it. The ones I have are the round body husky coils that won't work.
mdavlee
Hillbilly grinder
6:27 PM
TN
This 7900 feels very foreign to me,great looking and running saw though.
Morning mike.
They do feel different if you're used to a stihl or husky either one. They're different enough on the handle angles and spacing to not be really like either one. You just have to use one a good bit to figure out how they handle.
mdavlee
Hillbilly grinder
6:27 PM
TN
I think in the 95-98 range is where they're the fastest. Even with longer bars. The 100-102 does ok but has no wow to it.
5:27 PM
That's exactly what I've found too Mike. I can make a 044 really wow at 102........but not these weird bastards. LOL
mdavlee
Hillbilly grinder
6:27 PM
TN
Yep. I go to 98-100 on all of them now for work saws. Keith's is 98 or 96 and can run full comp on a 28" with an 8 pin no problem. I'm not using the stock piston though. I'm going to port 1 with the stock piston this week and if I have one more piston I'll do another with it to see if there's a difference. The piston swap is weird since there's no machine work involved. Quick piston swap and make a spacer and intake stays at 80. Raise the exhaust and transfers and open that lower to match the Solo cylinders and it's done. Just takes 2 base gaskets.
Redfin
Meh...
6:27 PM
Central Pa
So what the main difference these like the ex so high? Case volume?
5:27 PM
What piston are you using Mike? I tried the 272 piston. Didn't care for it.
I'm not smart enough to know. :(
Tractorsaw1
5:27 PM
SHOW ME MO
Does anyone have a pic of the 681 piston or is it any different than the 7910 slab sided piston?
Cut4fun
Redneck Chainsaw Repair
6:27 PM
Ohio
Mike you using the piston talked about on Chainsaw Repair? ;) I bet it is :p
