Machining for port work
Red97
7:07 AM
MI
Deets066,
Are you trying to "plunge" the cutter into the squish band?
Using the whole width of the cutter to cut the band?
If that is the case no "bar" is going to help.
You have to start in the center and feed it to the wall just like cutting on a lathe. Prepare for lots of broken carbide tips doing it by hand.
Best I can tell, from your video, you could set the depth of cut say.005-.010 with the cutter in the chamber feed it till it takes a cut in the band.
Spin the head till you feel no resistance, turn the Allen wrench a bit towards the wall of the jug. Repeat those steps until the band is cut. It will probably tear up quite a few inserts, and be a long slow process.
I don't see any other good way of doing it, also that bar you posted should work using the method I described.
Moparmyway
Its just a saw
7:07 AM
In a meeting
Where did you purchase?
I went to Shars, they invoiced me with total including shipping, then I sent a money order .........
It was locked up dry when I got it .......... a little Mobil XHP-222 and its smoothe as silk for the rest of its life
Deets066
AKA Deetsey
7:07 AM
Deets066,
Yes, plunge cutting was my first thought. I wanted to start on the cylinder wall but ran out of cutter at about .025, so I adjusted it in...cut some and then back out which was a pain. Then I took too hefty of a bite and pushed into the wall.
New plan,
3/4 boring bar mounted in a collet with no boring head and put the jug on my rotary table.
Tor R
Novice, Leg model #2
1:07 PM
Mandal
You guys that cut squish by hand,where are you getting your cutters? I'm getting a new double headed mandrel and need a new cutter.
+1,
I dont have lathe, but I would also like to get make so I can cut the squish by hand.
I saw the video to Scott
jmssaws
Banneded
6:07 AM
A guy just told me to get cutters from enco.
I got my last from the local machine shop but it's out of business now.
1\4" hss cutter
MG2186
6:07 AM
Summer,IA
You still need a lathe to cut the base though
Red97
7:07 AM
MI
New plan,
For the new plan, best bet would be a solid carbide boring bar... just long enough to get the job done. Or get an endmill ground.
Enco, MSC, production tool supply, ebay.
Just made 44.3,45,46,47 today. Tomorrow 50, 54, 55 :)
