Machining for port work
Deets066
AKA Deetsey
12:03 PM
I see this too, a fixture with a base plate like Randy's . Then a cage with four adjustment screws that come in from the sides and land on the side of the base. Or for even more holding power/stability two screws on each side/flat.
That's a possibility, but most jugs won't have enough thickness on the base. Like the 046, especially when removing .040 off the base too
Deets066
AKA Deetsey
12:03 PM
That works good cutting the case, but you have to do a full disassembly and new bearings and seals every time?
Mattyo
Youtube speciawist
12:03 PM
Farmington, CT
sounds like a lot of work for a wild thingy...
I like milling husky 350 riser blocks... VERY simple w/ a mill
super3
12:03 PM
Indiana
many of my vids contain milling, the vids are so boring though, most people never get there :)
i'll let you cheat and just watch this one...this is an ms200t
Why do you think +/- .001 is close enough?
super3
12:03 PM
Indiana
Matt,
+/- .001 from exhaust side to intake won't be a big deal.
Flywheel to clutch side is going to put side load on the piston.
Deets, I disagree with your thoughts on factory machine centers. Far more accurate than .001.
On a lathe set up you use an indicator with a lot more precision than the type in Matt's vid. .0005 graduations.
Not uncommon at all to get it dead nuts on.
Mattyo
Youtube speciawist
12:03 PM
Farmington, CT
without a better way to clamp a chassis, I don't think its possible to get more than +-.001. once I have a chassis clamped, I would need to somehow articulate the jhead to compensate for the differential...and I'm not sure it really matters that much.
would be nice to have more control w/ the milling, but I don't :(
still... I think it just doesn't matter that much... we are talking about a side load of .001...maybe .002 at the top of the travel of the piston. you are assuming that its better than that from the factory?
