- 4:45 AM
- Jun 5, 2016
- Northwoods of Wisconsin
im just thinking the oil will ruin the rubber is all
the brake spring just needs tension put on it a few times
different rubber compoundIf it can handle fuel (gas & Oil), then why would oil ruin it??? I think the ethanol is way worse than oil, and my fuel line is holding up so far.
There are posts where some have tried fuel hose as oil hose on the 026/036If it can handle fuel (gas & Oil), then why would oil ruin it??? I think the ethanol is way worse than oil, and my fuel line is holding up so far.
I worked at a custom mix rubber factory for over 3 years and I'd say the 2 hoses have different chemicals to cure the rubber
We made rubber for cooper and Bridgestone along with victaulic seals and other automotive parts
The only "non" Chinese parts in my saw are the piston clips, the chain adjuster (the one they gave me failed during installation), and the plug (because of the trouble I had on start up). I have used their plugs in other saws w/o any problems.
Don't have a lot of hours on it, but I've milled some Hickory with it, and it is still running.
I did not replace the dry main bearing, just put some 2 cycle oil on it and it seemed fine, and I'm using their piston bearing. Their recoil starters also seem to be much tougher than I expected them to be, and my saw oils like a pig.
Will see how long it lasts.
I'm doing the same thing. Only thing oem on mine is the chain adjuster.Hey Mike, I'm not knocking how anyone else handles their build, if you want longevity then some things are going to need replaced. I'm going for the opposite I want to see what's going to fail and why. This is just my agenda, I don't expect any one else to do what I do by any means. Having used parts from these folks in the past with very mixed and sometimes confusing results, I just can't but help be curious to know what can take this level of abuse that it was never designed for. Was just explaining to all why I'm worried about some things and others not so much. I think your oiler fix is going to be just great and even if it does soften up it really has no where to go and by then I'll be finished messing with it anyways.
