Little China Girl
7:25 AM
6:25 AM
Started turning, no turning back now. Took off a total of .045" that will yield a squish of .025" with a .020" gasket.
Was using a HSS cutter, it didn't care to cut through the plating. Used diamond ball burr to get the edge chamfered.
7:25 AM
No belt sander, like the pros use, someday...
I turn down the area between where the bottoms of your 54 and 56mm bases reach on your mandrel. Say your cylinder uses 3" of mandrel on each end of a 10" mandrel. That's 6" total. You have 4" in the middle that's unused. I turn that area down about 1/4", plus about 1/4" up into the cylinder area. It leaves room for a triangle shaped carbide to cut the chamfer. Sometimes it still leaves a burr in the nikasil and it's tough to get the cylinder off. Getting the unused part of the mandrel out of the way allows room for a needle file to clean up the chamfer
6:25 AM
Good to know, will do next time when it's for reals.
6:25 AM
Slammed her back together again. Now the flywheel hits the Cross logo. Squish with a paper gasket is .0245" one side, .0255" the other. So the band is out of square only .001". Might be I can sand it a bit with the mandrel. Otherwise it came in spot on for target of .025" finish squish.
Free port is at .047" on the exhaust port. Think I will try turning one more piston to see if this can be tightened up or eliminated. There is a little play at BDC between the crank and piston skirts. Not sure how tight this can be made, reckon I'll find out though.
Hopefully the crankcase can stay together now.
