Lets build a Husqvarna 262XP, SCARR style!
7:46 AM
srcarr52
7:46 AM
Iowa City
The kill wire gets tucked in with the coil wire and then splits off and goes through the slot to the carb box.
Remember the washer under the flywheel nut as it has a chamfer on the backside to take up the bit of crank taper that protrudes through the flywheel.
Coil takes the typical 2 series 4mm bolts with the larger 4mm Allen heads.
srcarr52
7:46 AM
Iowa City
Nice Job pal. I never had that flywheel issue.
People talk about the 046 jugs being the most varied. The 262 probably has the most jug variations I have ever seen. Best one ever was the Mahle non-decomp, not the KS, in terms of transfer tunnels.
It’s a lot of variation for a Husqvarna. So far I’ve heard of 4 different cylinders for it.
But there was probably more than 4 different cylinders of the 066 before it became the 660.
Moparmyway
Its just a saw
7:46 AM
In a meeting
Lesson learned today... just grind the dang flywheel!
One lesson I learned, aside from the dozens of lessons that I’ve learned from you…….. don’t cut into the magnet(s) when trimming down that flywheel. Guaranteed you will know it when/if you do
srcarr52
7:46 AM
Iowa City
I’ve had to nip the corner of the magnets before without any problems. I was able to stay out of them for this saw, no sparks when sanding!
srcarr52
7:46 AM
Iowa City
I like Threebond for this. Actually just pried the oil hose out of an 044 that rebuilt three years ago and it was stuck in there like shít to a blanket.
Threebond is ok but there is better sealing stuff. I tried to use threebond for sealing the case 1/2’s of my ktm 450 and it failed twice. OEM calls for a loctite brand sealant that’s a thick, black RTV. Turns out everyone uses the permatex right stuff. Pretty sure I could run it without the case bolts after that stuff cures.
Disciple of Monkey's
6:46 AM
I think I'm on my fourth different way to build a 044 cylinder now.
beaglebriar
The Peanut Gallery
7:46 AM
Warren Center, PA
Yep that Right Stuff is awesome I use it on diff covers. It takes a lot of prying to get it loose. Never tried Threebond on case halves but I've used yamabond and hondabond, always had good results with those. I suspect those three are all similar if not the same.
6:46 AM
All from Japan and with "bond" in the name, gives the clue as to the maker.
