MG porting
- 10:03 PM
- Jun 28, 2018
- Wa
Maybe he's tired of us.lol
Pretty cool stuff and how I see it there all good runners time to port the 500i now?Sorry, I did not have much time left over the last few days, but i'm on it now![]()
before i forget, here is the 7pin vid with the 500i and the 462 (and a new and stock 390xpg)
I'm most excited to see how the efi performs with a port job.Pretty cool stuff and how I see it there all good runners time to port the 500i now?
Me to it could be good or bad pending if it can adjust to it and there's only one way to find out.lolI'm most excited to see how the efi performs with a port job.
In my experience, the 462 does not make the RPMs of either the 461 or 460/046.462 just flat hauls rpms in the wood in my experiences, but not heaps of low end torque. A fast and rather highly strung saw. How’s the 500i’s torque feel in comparison?
It’s my understanding it has a MAP/pressure sensor, a temp sensor and ability to register crank speed. Those are enough for speed density but in the Automotive world, speed density systems have a throttle position sensor and use an oxygen sensor to check whether to deviate rich or lean from the base map. Think GM TBI systems, Honda PGM-FI, etc. Systems with no air flow meter/MAF sensor.So the saw has no map sensor or anything? It can't be strictly map(tuning) based provisions. The has to be some sort of reference to temp and density altitude...at least.
AJ you make my head hurt![emoji6]It’s my understanding it has a MAP/pressure sensor, a temp sensor and ability to register crank speed. Those are enough for speed density but in the Automotive world, speed density systems have a throttle position sensor and use an oxygen sensor to check whether to deviate rich or lean from the base map. Think GM TBI systems, Honda PGM-FI, etc. Systems with no air flow meter/MAF sensor.
My bike (98 VFR) is FI. It actually still has a manual “choke” though for cold starting. It’s really an enrichener/starter jet, not a choke plate. My RC51 was the same way. They use a programmed FI system which has no feedback measures. It’s all in the mapping. It uses air and engine temperature, throttle position, rpm and load or calculated load inputs to derive the proper injector pulse time in milliseconds. It does compensate for weather and condition changes but it’s still a predetermined, programmed value.
I’m totally guessing here, but I bet this system is similar in function.
Said no man ever...[emoji13]You need an ice cold Pabst
