- 9:02 PM
- Feb 5, 2016
- grafton wv
past dinner time hes lateIts dinner time...
lol i could say something but i wontLol. I ate well today. Both sides of family over. 1 for brunch, 1 for dinner. I am stuffed!
First thing. Lot of work and effort put in by Steph on this Vid...
A few points here dealing with the standard saws....
8 pin drive sprockets...Is that what each maker fits as standard ? . Pros and Cons here.....gearing up has some negative outcomes regarding overall speed /and wood type performance as well as giving the chance at more chain speed.
The HP output of the saws has got a chunk of grunt difference between the most powerful and the least.
"Rated" power stats ....Stihl 500i = 6.8hp and the Dolmar ps-7910 at 5.76 HP =(5.9 ps).
The 572 and 462 are nearer each other in time/cc and HP so you would hope they were close to each other.
Run time...
Are they all more or less new?
Variables to be had there as well in the future perhaps.
Out of curiosity, what kind of wood is that you are testing in?
all I was gonna say isNo reason to say anything. Silence is Golden.
Momma always said if you don't have something good to say then don't say it at all.
I just made the point of reference to 8 or 7 pin because 7 pin is what the 7910 and 572 seem to have as standard supply in 3/8 set up (in the UK is my information) ... I see that the 462 shows the option of both on the IPL.I actually thought that an 8pin for the 500i is an advantage because more displacement, power and torque on the paper, compared to the other saws. I can repeat the test with a 7pin, no problem. But i don't think it will change the outcome that much at the moment.
To the runtime, the 500i now has about 7 tanks through after my testing and some firewood cutting. The 572xp is the demonstration saw from my dealer and has 40h on the clock. The 462 is from an arborist, buddy of mine, easily up to 100h runtime. The 7910 from my dealer was a training saw for apprentices at the forestry school, over a year in use.
Sure, the 500i should gain a bit over time, still pretty new.
Here's a chart with stock numbers out of the german "KWF Prüfbogen Index" the 500i looks impressive on paper, the 572xp not really in comparison
spruce![]()
Don’t think we’re on wives tail territory at all, every new engine requires break in some more then others. Heck some of the more sophisticated 2 strokes limit power and add more oil while breaking in fro a certain number of hours then once that required time is done it’s full power
spruce![]()
Are you feeling ok or does someone need to make you a cup of soup?
