Inside the.....? (solved, MS 500i)
3:12 AM
Firs thing. Lot of work and effort put in by Steph on this Vid...:)
A few points here dealing with the standard saws....
8 pin drive sprockets...Is that what each maker fits as standard ? . Pros and Cons here.....gearing up has some negative outcomes regarding overall speed /and wood type performance as well as giving the chance at more chain speed.
The HP output of the saws has got a chunk of grunt difference between the most powerful and the least.
"Rated" power stats ....Stihl 500i = 6.8hp and the Dolmar ps-7910 at 5.76 HP =(5.9 ps).
The 572 and 462 are nearer each other in time/cc and HP so you would hope they were close to each other.
Run time...
Are they all more or less new?
Variables to be had there as well in the future perhaps.
from what ive seen on the mtronic saws they like being loaded down
a 7 pin doesnt do that with a shorter bar if you think running 12k rpm in the cut is good you are a fool
MG porting
12:12 AM
Wa
Can't we all just get along.:brush::dancing:
