nohoff
professional flusher
- 11:19 PM
- Sep 11, 2017
- Germany
I just stretched the spring a bit. And increased the pressure to 112 mbar.
The pump looks just like a carb. The pressure part is regulated by a spring on the needle side diaphragm. The spring is on the side where on regular carbs the atmospheric pressure presses on the diaphragm. Just open the 4 screws and you can work at the spring. After that put pressure on the tank side of the pump and use a gauge on the injector side of the pump to read pressure and check.
Only thing i got is hot start issues and some smoke.
