lehman live edge slab
Live Action
- 12:40 PM
- Sep 2, 2017
- Mn
the result of trying to remove a locktite screw
Did you make it out alive?
Are the Solo and dolmar also new?
Or are they allready broke in?
How certain are you that it can be accessed and modified?there is a spring in the injection pump which closes the needle when 0.1 bar is reached. You can add a washer under the spring to set the pressure higher.
