HUSQVARNA HUSQVARNA THREAD
peter92
3:57 AM
maryborough qld aust
This is the aftermarket 268 piston. It's made for an open port cylinder. No windows
This is the proper 266/268 closed port windowed piston. This is a meteor but oem looks the same
Thanks for showing me the diff , would it make much diff to the saw if the wrong one was put in , not that i have , need to check the cylinder and piston on mine yet
Peter
  • Like
Reactions: DSS
DSS
widebody
2:57 PM
canuckistan
The windowed piston should be fine in either one. The non windowed one will run in a closed port cylinder, but it won't work very well
peter92
3:57 AM
Just a question
a piece off the 394xp cylinder broke off a bolt hole on the base , can it be repaired
and how would it be done
Tig weld i guess but would the base need to be machined
would it be ok once repaired
Peter
Duce
1:57 PM
Roscommon, MI
Just a question
Peter
Contact srcarr52, sounds like he has a plan.
Stackowood
10:57 AM
West coast
Right, I've tried some red images but I can't seem to get them re-sized to fit the avatar box. :confundio1:
peter92
3:57 AM
Can any one tell me how to adjust the chain brake on a 266 , it doesnt seen to stop when i push the lever forwards
Peter
12:57 PM
Peter
Chain brakes are over rated
DSS
widebody
2:57 PM
canuckistan
yep i know , but ive got a 4 yrs old grand daughter
Take the cover off and see if the brake band is broken. Those are hard to find, there's some on eBay UK but the shipping is ridiculously high.
peter92
3:57 AM
did that band is still in tac
didnt take a pic of it
