Gord
- 11:24 PM
- Dec 14, 2018
- British Columbia
Great info, thanks, skipped over to the carb fix as well.
13,500 I believe Depends on which muffler it has but another outlet almost always helpsWhat is the factory spec max rpm of an Husqvarna 365 Special?
Is it identical to the rpm of a Husqvarna 365?
Asking to set up my neighbors saw.
Also, is it just me or does a Husqvarna 365 Special desperately need a muffler mod?
That factory stock muffler outlet is tiny!
I didn’t see any cracks, but I had that same issue on a 350 and it drove me up the wall trying to find it, mostly because I thought my block-off plate was faulty.And while there's a little life to this thread at the moment, here's something I posted to the 357/359 specific thread a couple days ago that I probably should have cross-posted here anyway.
We all know about the intake leak issues with the plastic snap clamp debacle and the associated fixes on the saws that use that intake setup.
I recently ran into another air leak problem with that intake setup that I haven't seen much about. Drove me nuts nailing it down and it probably could have been tuned out, but I rebuilt the same saw for the guy 3 or 4 years ago and it was completely tight when I finished it then. No reason it shouldn't be again.
Here's what I found this time around.
Appeared to be leaking behind the flange since that's where the bubbles were. I'm wondering how the hell that's even physically possible since the boot seals against the front surface of the flange.
Had it apart a few times before pulling the bellows (boot) out of the flange and finding these cracks. They didn't go quite all the way through and weren't visible from the opposite side. That woulda been wayyy too easy. LOL
Anyway, just a heads up if you service one of the saws using this type of flange/boot arrangement. Most likely a pretty good chance there are more of these out there than just this one. Also a pretty good chance the condition was caused by excessive tightening (possibly by me last time around) of the intake assembly and the cracks occurring over time. That said, I've only heard of these flange threads stripping, not cracking. Regardless, if cracks are present, they'll be hidden if they don't go all the way through the flange. Might be something to consider checking as part of your routine when working on these saws.., especially if you're dealing with a pesky intake leak.
Thank You very much Kevin!13,500 I believe Depends on which muffler it has but another outlet almost always helps
Yep it’ll be fine thereThank You very much Kevin!
She sits at 12800rpm now with a 16" hardnose B&C.
Considering the operator does not know how to sharpen a chain I will leave her tuned a little rich.
Muffler has a tiny little single outlet.
Again, considering the operator I will leave the muffler stock.
Check if your muffler has baffle in it? Those early 365 I own has baffles in them. The 1998 and 2000 one. The 2004 I own does not have baffle in it.What is the factory spec max rpm of an Husqvarna 365 Special?
Wierd never seen a baffle in one.Check if your muffler has baffle in it? Those early 365 I own has baffles in them. The 1998 and 2000 one. The 2004 I own does not have baffle in it.
Not my saw, I don't care!Check if your muffler has baffle in it? Those early 365 I own has baffles in them. The 1998 and 2000 one. The 2004 I own does not have baffle in it.
Neither have I and have done up a lot of themWierd never seen a baffle in one.
I have two videos of this gal, shall I upload them to the Tube?She feels a little tired fully loaded, may need new rings, starts great cold and warm though.
