PogoInTheWoods
- 1:12 AM
- Apr 23, 2016
- Ohio
Here's some pics of an open and closed port side by side. On the ones I have the transfer tunnels on the closed port are rounded and are more square on the open, the top fins are also different. The top one is the open port in both pics48zn5 is definitely the 162/630 cylinder. Now, is there a pattern to which 61s have that cylinder, or is it completely random? I may need to try and scare one up for research purposes if we can identify what to look for.
You do Facebook?
Yes they areHi guys, thought I'd ask the husky experts. Will a 272xp cylinder and piston fit on a 268? Looked up the numbers, and they take the same crankshaft and cylinder gasket, so I'm thinking it will, but dont play with huskys that much.
I dont believe so, one of the members here just did a YouTube video of the conversation from concrete to wood saw.Does a K1250 have a different crank than a 3120 relating to the stroke?
42mm?
Link?I dont believe so, one of the members here just did a YouTube video of the conversation from concrete to wood saw.
No. Same crank.Does a K1250 have a different crank than a 3120 relating to the stroke?
