Husky 394/395 thread
Wolverine
dilligaf
1:05 PM
I think I took 1mm off the intake skirt (thickness of base gasket included). The 395 piston skirt is even shorter. I was gonna try raise ex 1mm too but decided to be conservative. Didn’t even widen ports or anything.
Hmm. Didn’t realize that. I got a 395 Meteor since the OE piston was not included (bought in a box), so I never was able to compare them.
1:05 PM
I’m not sure about the meteor 395, but the couple 395 oem pistons I have here are all much shorter skirt than meteor 394 and centered ring pin vs on sides. 1.2 vs 1.5mm rings as well.
smokey7
1:05 PM
Detroit
Is the shorter 395 piston shorter in compression height or pin to skirt?
dustinwilt68
Wilt Built Work Saws
1:05 PM
Southwest PA
Currently I am down to 3x 394 and a new 395xpg, I sold the one 394 but it found its way back home to me, they are like boomerangs apparently, I probably have all but enough parts to build 2-3 more there, they wouldn't be the prettiest saws, so I just keep them as parts saws for now, till I get time to really build them like i want to. I do have a fresh set of powdered cases to start on one, if I can ever get caught up on porting saws for customers, maybe February.
p61 western
Ol Mudflap
10:05 AM
GFY
What do you guys like to do inside the muffler? Cut the baffle out? This is a am muffler, so not worried about hacking it.IMG_20191227_173249.jpg
1:05 PM
What do you guys like to do inside the muffler? Cut the baffle out? This is a am muffler, so not worried about hacking it.View attachment 216975
I add another deflector right in front of the stock one. I believe that area is outside the baffle/tube
