Husky 394/395 thread
RIDE-RED 350r
10:44 AM
Blossvale NY
In my limited experience, I found the Mahle cylinder to be better than KS for a 288. Like to hear from more experienced hands how they compare with the 394.
dustinwilt68
Wilt Built Work Saws
10:44 AM
Southwest PA
Generally the Mahle are closer to the numbers most porters want, also I believe the transfers are smaller in the KS, not certain if that's a + or a - though, guess that depends on the porters preference in how they like them shaped and what size.
RIDE-RED 350r
10:44 AM
Blossvale NY
That's exactly what I found to be the case with the two brands of 288 cylinders, at least with older specimens. Josh's new current production OEM KS 288 cylinder is quite strong though.
suttererman85
10:44 AM
Fort Worth
She’s ready to sing [emoji41]
Fruecrue
certified hand catcher
10:44 AM
Alden NY
Fresh rings and hone, all stock.
The seal collar fell apart, new one on order.
Couldn’t help myself, put it back together for a test run. My first 394. Perhaps it needs to break in but it wasn’t what I expected it to be.
Skeans1
7:44 AM
32 or 36? Square or round?
If you go back up a ways my saw is a little bit of port work but will pull a 42 with a 8 pin in oversized fir and a 60” with a 7 pin all chains are square ground falling chains.
Fruecrue
10:44 AM
Alden NY
32” round, freshly sharpened.
cus_deluxe
terms of service violator
10:44 AM
Michigan
Yep, softwood and hardwood are different haha. Hard to tell dave but i feel like you could expect a little more from that too, but give it a couple tanks of fuel and see what happens. And put a 7 on it haha
Skeans1
7:44 AM
I cut hardwoods too trust me with a 36 8 pin with square, I’m not a firewood guy I make a living falling timber the faster I can put down wood the more I make.
cowroy
10:44 AM
Tennessee
In my experience I’ve had saws that break in quick and others just don’t. It may take two or three gallons of fuel to really get it run in good.
I need another 394/395. They are just a great saw for long bars, and I’ve got several big trees coming down soon.
Fruecrue
10:44 AM
Alden NY
I’m not stuck to it, I can bring it to Tennessee if you need another.
10:44 AM
This is the 394 I have here when it was stock with 28” 8 pin semi chisel in dead ash I believe. It was a ahead of a stock 661 by a touch with short bar. Never tested with a long bar.
