Husky 372xp tips and tricks - my first husky rebuild
Brewz
12:51 AM
Hunter Valley - Australia
I will drop into the local Husky dealer and order an o ring
I also want to replace the little rubber but that holds the oil pump pipe in the pump.
If you guys in the states are thinking its a good price for a 372 then its half price in Australia!
I will chase it
RIDE-RED 350r
10:51 AM
Blossvale NY
Pretty good looking saw for its age. IDK exactly when they redesigned the recoil screens and the older style like on that saw went away, but it was a good while ago. I would expect to see that saw priced right in the ballpark of what you stated here.
Mattyo
Youtube speciawist
10:51 AM
Farmington, CT
That 372 is an oldie... but it looks as if its had little use. Check the chain catcher for wear and the front of the chassis for paint loss. Will give you an idea of how much its been used. :)
Glock37
10:51 AM
Monroeville Pa
I've done gobs of these damn huskys and still forget to do that now and then.
Im putting one together a 365 sp to 372 2 hrs yting to put carb boot plate on with cyl on. Well i wire in recess on boot and push plate forward as u pull wire out and it installs groove over plate Like installing a windshield
Just a lttle fyi
Glock37
10:51 AM
Monroeville Pa
if you like this 371 I am pretty sure you will like the rest of huskies pro saws, even 550 is workable.
Since you do full rebuild I doubt you will get into any trouble, the only thing you need to pay attention to is this silly little o-ring that you find on PTO side.
Matt have a great video about that issue.
Where do oring go ?
Tor R
Novice, Leg model #2
4:51 PM
Mandal
The last picture tells me it has not done a lot of "big" timber
it doesnt look to have seen much wood in it's life.
See if you get a picture of the bottom of the saw, but I like what I see :)
Brewz
12:51 AM
I am really impressed with the air feed design to the air filter using the flywheel like a turbo.
The one I am re-building had this passage about 30% blocked by oil and gunk but I am replacing seals to stop a suspected oil leak from the pump outlet
Either it leaks or these huskies oil like a *b-word!...... as I have read they do.
Brewz
12:51 AM
It was set to about 60% open with a 20" bar
what should it be set to on these with a 20" bar?
It was completely coated in sticky oil...... which has preserved it well but it also clogs everything up
