Husky 162/272--Jonny 630/670 project thread.
Johnmn
5:27 PM
Minnesota
That's awesome - still available? I need 1 for sure.
No they are NLA and have been for quite a while. They do pop up on eBay from time to time though. The intake has a wider stud spacing where the filter screws down, so you need both. I can check but I believe I don't have anymore.
Johnmn
5:27 PM
Minnesota
@Czed my intake says 503 40 05 on it and that's it no -01 or -02
Johnmn
5:27 PM
Minnesota
I'm about 99% sure that one at chainsawr is it
Johnmn
5:27 PM
Minnesota
Is the filter or the intake the hard to find piece?
Both I believe, with the intake the flywheel side takes a regular bolt but the PTO side needs a longer bolt.
I'll get a picture......
Johnmn
5:27 PM
Minnesota
Building another 6xx series j-red with a 266 top end. I just wanted to share some things that I like to do when going through these saws.
Parts cleaned up and ready for assembly.
I heat my cases up in the toaster oven.
While it's heating, new seals and o-rings
@Mattyo tools make assembly a breeze.
I didn't snap a picture but I like to smear a little 518 on the cases as well as the gasket.
I like to put a little grease on the back of the seals before I install them. Just a little extra insurance in my opinion.
Johnmn
5:27 PM
Minnesota
This series of saws seems to leak bar oil when sitting. I put a little 518 on the back of the oiler line, it has cured the problem for me.
These like a timing advance, .030 is what I like to take off the key.
I sanded the squish from .015 to .019 and sealed up the base with 518. A new pin bearing, meteor piston and caber ring.IMG_20200111_172137976.jpg
This is as far as I got hoping to finish tomorrow.
Tractorsaw1
5:27 PM
SHOW ME MO
Johnmn
5:27 PM
Minnesota
