mrxlh
I stayed late and finished!
- 6:25 PM
- Dec 2, 2020
- Dat Boot
Ok I was wondering why an idle screw carb wouldn’t work on a 268/272 case, makes sense with the 61 case.
I have some old tillotson hs carbs mostly from dolmars though I could look around and see what I have if you would like?
https://opeforum.com/threads/jonsered-6xx-husky-266-8-72-spring-av.15835/I'm curious what this 288 spring mount trick entails?
Question - did the husky 61 ever have a limited coil? I have a grey top 61 two piece ignition, it’s acting like it has a limited coil and I didn’t think these saw ever had them.
Unless you have a kill/spark wire shorting out type of issue, I'd say your saw is on its way to total ignition failure. Least ways every one I've ever seen start acting up ended badly. They just have too much age on them and when one half starts to go, it's not long and the other half follows suite. Best to replace as a set.
The two I dealt with acted like they were limiting rpm also then they just completely quit. Ended up with the Chinese 2 pc set in both of them and so far they’re lasting been 3-4 years at least.Thanks Steve. I talked to Pat about this as well. He said there might have been a cut off saw version and somehow that ignition found it's way onto this one. I might try taking the ignition advance out of it just to make sure I didn't take it too far. If it's an ignition issue, it's very consistent at the rpm it starts cutting spark at. I don't have much experience with failing ignitions though...
I will report back with part numbers to see if you guys might be able to help me cross out a cut off saw ignition from the list.
