HELP! How to know when you have too much hook
4:14 PM
As said, I own a Husky roller guide.
Interference was minimal.
Take a mild file stroke off both sides then check fitment, You don't want it too loose as it'll wobble otherwise.
4:14 PM
Most pro & semi pro users on here deem this grinder sloppy and inaccurate.
It was my salvation from hours of filing and I work with its flaws - have no issues with it whatsoever.
And YES, the chain clamp and motor mount swivel around so that both LH & RH cutter are ground from the outside in and the sparks always spray away from the operator.
Mine is an elder unit, they are still making them though.
4:14 PM
That's cheating.... wait you can reverse the chain!!!? I want one!!!
Not a cheater, just working less hard!
I also have a BAHCO file guide, several of those guides that clamp on the bar, and I believe a Oregon filing kit.
I just got sick & tired loosing whole weekends filing chains.
The steep decline in round file quality by Stihl & Oregon didn't help either.
SawAddictedFarmer
9:14 AM
Do you still file at all? I can file as fast as I can grind if it's just dull from cutting.
SawAddictedFarmer
9:14 AM
Can you get Pferd/Vallorbe files?
4:14 PM
Possibly off eBay, but I found the Husqvarna Intensive Cut files, round & flat, to be good.
I only file chains in the field, I exclusively grind at home.
I will file my play chains to get that extra sharp edge, though those don't come out often.
4:14 PM
If I recall correctly I could notice an edge from the stamping process and I just mildly filed that off symmetrically on both sides whilst testing fitment after each file stroke.
As said, You don't want it too loose and it will wear through usage anyway.
STOVE
10:14 AM
Eastern NC
was bored this afternoon and decided to practice some more. The file is still not sitting as deep as it should. It did decreased the hook, I think the angle is far less drastic as well. A few times it was only hitting the area I highlighted red
Squish9
12:14 AM
That will cut OK. You can adjust things to suit the power and wood type you are cutting. A cutter like that will allow a little more depth gauge if you want a bit more cut speed and it will hold an edge well
4:14 PM
First picture (0914) is what You should aim for, second picture (0916) You are a bit too high.
The guide still doesn't seem to sit flush on the chains tie straps in the first picture, which may be why Your file is too high in the second picture.
I'd double check that.
HumBurner
7:14 AM
Humboldt
if you end up way under cutting the teeth you can fix it with a bigger file to cut some of the top plate back and then profile it back to the correct shape with the correct size file.
This is how I often will deal with cutters that are rocked bad. Instead of making tons of strokes with the appropriate file, I'll grab a smaller than typical file and take down the top as needed, then hit it with a larger than typical file to even it all out. Then take a few strokes off the depth gauge and round it out.
STOVE
10:14 AM
Eastern NC
Latest hand file practice. Certainly room to improve. The husky roller kit is worth it for the raker gauge and flat file alone. These look less “aggressive” to my eye.
Trying some tilt, 7/32 file. Haven’t gotten comfortable with the 1/4 @davidwyby sent me. Hit a few with the 1/4 first then finished with the 7/32.
10:14 AM
View attachment 472211View attachment 472212
Those look good to me. Set the rakers so the saw cuts under its own weight without you having to push or dog in and you will feel the bliss
HumBurner
7:14 AM
Humboldt
Thats about where I like my chains for bucking hardwood; looks durable with a lot of meat. Also looks like you're getting a bigger bite with the 'C' part of the cutter and not the top, which is also my preference. I'd definitely take the depths down a stroke or two, then round them out. Make a few cuts, and as @huskihl said, if the saw isn't feeding itself smooth (cutting one-handed in a log is a good way to tell) under its own weight, take another stroke or two off the depths and round the top out again.
Edit: A fast chain and a durable chain aren't mutually exclusive. Semi-chisel can cut quickly, and full chisel can be tailored to be more durable while maintaining speed.
