sawnami
2:47 AM
Springfield
Do you have an address or location for Dan in Tulsa?
Dan is in Brookhaven Hospital NRI. She put your name on the visitor list just in case you get a chance to drop by.
She's in need of some help to prepare for a personal property auction next month on the 17th. She's going to sell all of Dan's saws in the auction in case there would be an interest.
67L36Driver
1:47 AM
Weather prognosticators missed on the high temp. Maxed at eighty eight instead of ninety one. More important, the air is much drier than predicted. [emoji106]
Hope we get a repeat tomorrow. [emoji1696]
Stihl trying to turn down the Oiler on a Echo 660. [emoji2960]
Workshop
1:47 AM
Nixa, Mo.
Bigger screwdriver.
rsting
1:47 AM
Just a big pussy cat to start.
I flooded it good with a dribble to avoid lean kickback.[emoji16]
Dialed in the carb a bit and turned down the idle.
Found the Oiler adjustment and turned it down from OMG!! high.
24” should be the minimum length on this. [emoji2960]
Wow! Nice saw. Not too many of those around.
67L36Driver
1:47 AM
Echos will run you out of 5mm x .8 Helicoil inserts. [emoji57]
It’s the long overhang on the muffler.
Notice the ‘ear’ broken off. Once that goes, wallowed or broken port bolts not far behind. [emoji90]
Take notes Steve.[emoji106]
67L36Driver
1:47 AM
And, a random Stihl muffler gasket from my stash fit perfectly. [emoji6] The 660EVL that is.
I wonder how many more in the pile have loose mufflers. [emoji51]
Edit:
Checked seven of the other EVL types and all but one needed 1/16-1/4 turn on the muffler bolts. [emoji57]
