67L36Driver
6:14 PM
36" X .404 Poulan bar was just delivered. May need a helper handle for the 655BP.
Remington SL-55 made it to Lenexa KS.[emoji12]
Hedgerow
6:14 PM
I want it to be a strong work saw
Need the stock #'s to see what the factory was looking for.
Closed port & Dual port?
Bore x Stroke measurements?
shorthunter
6:14 PM
West Central Missouri
I want good port timing numbers for it
I would buy a couple of cheap pistons and grind/ file on them until you find some numbers that you like. If you go that route, I would start with 152° duration on the intake and exhaust and 18° of blowdown. Run the saw, pull it apart, file, reassemble, repeat. Set your intake first, then your exhaust and finish with your transfers
lumberjackchef
6:14 PM
Southeast Kansas
This is what acres site says about stoke and bore if its correct.....
Sent from my MotoE2(4G-LTE) using Tapatalk
Workshop
6:14 PM
Nixa, Mo.
You can never have too much knowledge, Brandon.
Proud of you, keep it up.
