MG2186
- 10:27 AM
- Jan 3, 2016
- Summer,IA
Good Lord, we finally got a darn good rain... I was planning on doing some cutting today (with my day off) but may use it instead to catch up on chain sharpening and such.
On the Ford subject, to get/make the 6.0 in Dad's truck right, it took Studs, EGR delete, tuner. new oil cooler (x2...), redone FICM and glow plugs/controller. For performance/longevity, a 4" straight exhaust was added along with a FS2500 Oil and Sinister coolant bypass filters.
All of this "fixing" was around $4k... If I could do A 6.4, properly for the same or less, then I'd be interested in that!
6.4s are amazing when tuned right, I'm just leery of buying one on the edge of grand failure do to previous neglect/abuse, especially if some would-be John Force or Don Garlits owned it previously... Now, ANY engine could fall into that same category and I get that, but some seem to give a bit more warning before the take a huge dump on you...
That there is the problem, a lot of failures are do to crappy maintenance, and to john Force analogy because they are fast when tuned properly. I have a friend that works on diesel pickups for a living, mostly Fords and Dodges and few s Chevy's. He said 75% of the problems come from crap maintenance and neglect! When I buy a 6.4 truck, I will more than likely pull the motor right a way and just build it the way it needs to be done so I won't have to worry about it and what others have previously/potentially screwed up on it
