Workshop
- 3:46 AM
- Jan 19, 2016
- Nixa, Mo.
Not delivering enough fuel to run high speed. Plugged fuel filter, bad fuel line, blockage in the carb. Replace the first two, clean and rebuild the latter. A plugging fuel filter will affect high speed running first ( high fuel demand) then gradually affect idle. Gets plugged enough it won't let fuel through at all. Did they run/store it with e10 fuel in it? Also, non-synthetic oil mix can let bacteria grow in the carb passages and plug the fuel passages if left long enough.Ok saw question. Friend got an 009 and it runs but at full throttle it starts to run then dies.
