- 10:48 AM
- Apr 13, 2020
- 5543X, 5644X
So there is a theme to primer being applied!
That at Stockton?View attachment 398393
View attachment 398394View attachment 398395View attachment 398396
It takes a certain amount of insanity to go out on a cold windy day.
I'm not a good story teller, so here's some pictures.
The glass is great.View attachment 398383View attachment 398384View attachment 398385View attachment 398386
Oh...View attachment 398393
Leupold vx3-i LRP 8.5-25x50 ffp matte.
$900
They are dandy scopes.The 257 Roberts I got had one of these on it, basically my son & I figured i got gun at at no cost & a healthy discount on the scope.
They are nice scopes.
Yes sir, Ackley improved heavy barrel. It must be a custom build, there were no markings other than Ackley 257 on it it.They are dandy scopes.
So you did get the 257 then?
$625 was a steal with that scope on there.Yes sir, Ackley improved heavy barrel. It must be a custom build, there were no markings other than Ackley 257 on it it.
The barrel is only 18” so the improved part is moot. All the reading I have done says you need to 24” barrel to get the gains, so it will just get fed factory ammo.
Bottom one is a
Browning X-bolt 7mm Rem Mag with rings,
new never fired.
$625 each
Good deal
That‘s what my son said, he thought maybe I got the deal of the auction.$625 was a steal with that scope on there.
My uncle Jim swept and straightened up Ackley's shop for awhile. Factory ammo may show you a different case shape if it's an improved chamber. The case is less tapered and the shoulder is 40° IIRC. Provides the "most efficient case capacity for bullet diameter" from Ackley's books on loading for innumerable cartridgesYes sir, Ackley improved heavy barrel. It must be a custom build, there were no markings other than Ackley 257 on it it.
Bottom one is a
new never fired.
$625 each
My son is going to get the reloading accessories, he has already done the reading & research on it. Thats in his wheelhouse not mine.My uncle Jim swept and straightened up Ackley's shop for awhile. Factory ammo may show you a different case shape if it's an improved chamber. The case is less tapered and the shoulder is 40° IIRC. Provides the "most efficient case capacity for bullet diameter" from Ackley's books on loading for innumerable cartridges
If the case comes out looking like my description after firing, it is a "257 Robert's improved" for which reloading dies are made or a neck sizer only since only one rifle will be fed these loads
Glad your auction time was well spent.That‘s what my son said, he thought maybe I got the deal of the auction.
They were still selling handguns when we left, then the had 3 tables of scopes & a ridiculous amount of ammo to sell. Your post on scopes helped me make my mind up leave. 6 hrs of standing around elbow-elbow with 200 other folks was getting old.
Yes Sir!Happy Monday!
Now get to work Slacker’s
