67L36Driver
10:17 AM
Starting to think that I might have the same problem Bryan.
Oh well……
I just want one of every make & model.
[emoji58]
Sawdust Man
Manufacturer of Sawdust
10:17 AM
MO USA
Borrowed my bil's splitter for some elm.... dang, that's nasty stuff!
Also, got a new saw in the mail yesterday that we've been testing out.... shindaiwa 492 I'm running a 20" .325 setup.
Nice and light, not the most amazing av, most of it's power is in the form of low end torque....
Near as I can figure out it's the same as the echo 4910, same carb, same coil, same piston & cylinder.... but idk....
So far I kinda like it.
Under the cover after 4 or 5 test cuts.... maybe not the best air filter system....
Workshop
10:17 AM
Nixa, Mo.
Years ago my Uncle would let me cut my firewood off his place. I cut down a good sized one and he came driving up, got out and said that’s a black gum. It’ll be hard to split. I was young, strong and stupid then. I said that’s ok, I’ll get it split. (I was splitting by hand then). Got the stuff home and hammered 2 steel wedges ALL the way flush. Never even phased that piece. Those wedges were stuck in that chunk until it dried out. Even then it took a saw and axe to get my wedges out. Nowadays I’m old, weak and still stupid but I have a hydraulic splitter now.
Sawdust Man
10:17 AM
MO USA
Elm gives any splitter a workout! Human or machine!
I had never seen anything like elm before I moved down here....in the PNW the worst splitting wood is some of the second growth spruce, it's pretty stringy and super soft... but it's child's play compared to elm....
I made a video to show my brothers how bad it was, cause they couldn't believe it could be that bad!
JimBear
10:17 AM
IA
Best to cut that when it’s dead & the bark is falling off or has just fallen off. It splits much better when it’s dry also.
Sawdust Man
10:17 AM
MO USA
Yeah, most of the elm we split today was pretty dry, and some of it split kinda okay, but there was one log that was really bad.
Btw, is it even any good for firewood? It seems really light in weight when its dry, kinda like cottonwood...
hoskvarna
10:17 AM
Iowa
Very good firewood
I’ll take red elm over oak
Sent from the Hoskey Hill country
JimBear
10:17 AM
IA
In my experience:That spaghetti split you have will burn fast & not throw much heat.
Usually fresh cut live elm splits like that & burns fast
Dead elm usually splits well & throws good heat.
It’s like burning two totally different species of wood.
I always get clinkers when I burn elm also, hard chunks of mineral deposits.
Slippery ( Red ) Elm is highly sought after around here. It will lay around several years before it starts to go bad.
American Elm looks like what you had & is good stuff if you get it before it gets punky.
Siberian Elms are good for shedding limbs & firewood in a pinch but I usually just send it to the brush pile.
sawnami
11:17 AM
Springfield
Morning midlanders! Some 20 degrees warmer this am than yesterday. [emoji106]
Been trying to thin the herd but only getting ‘tire kickers’ on Facebook.
Oh well……
You guys and your chainsaws sheesh! [emoji849]
Sent from my LE2117 using Tapatalk
Cat 525
10:17 AM
Central Kansas
There is alot of different in the amount of heat and ashes that the different elms make. Red elm is top notch. We have Chinese elm here that ain't worth nothing! Wouldn't even make a good fire to roast a marshmallow.
Sawdust Man
10:17 AM
MO USA
It's all winged elm I've got here, near as I can tell.
